mca mca is offline
mca's Avatar
CO% on 911 SC - Should it be adjusted for street and track days?
I was wondering if the CO should be adjusted for track days.
Is this a good idea or bad idea?
If it makes sense to adjust the CO, what should it be for street driving and what should it be for track days?
Right now mine is set at 2% and was thinking 3% would be better at the track.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 09-18-2008, 02:06 PM
RETIRED
Joe Bob's Avatar
Rich is good....lean is bad......
2012 ML350 3.0 Turbo Diesel
Old 09-18-2008, 05:47 PM
Designer King
Paulporsche's Avatar
I know JW has recommended 3.5% for these cars. It corresponds to about 13.2:1 A/F ratio. I remember seeing specs for 911s in pre CAT days, like my original '77 engine, and they recommended a max of 3.5%.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-18-2008, 08:06 PM
mca mca is offline
mca's Avatar
Here is a good source for converting CO% to air/fuel ratios:
http://www.perfectpower.com/technical_info/afr.asp
2% CO = 13.77 AFR
3% CO = 13.38 AFR
3.5% CO = 13.20 AFR
Old 09-19-2008, 07:07 AM
What is considered the "ideal" a/f ratio for max performance without risking an excessively lean condition?
356robo
70 T Targa
Looking for a 2.2,2.4, or 89 coupe
Old 09-19-2008, 09:43 AM
Designer King
How about 13.2:1 @ WOT?
Paul
Old 09-19-2008, 12:48 PM
CRNT918's Avatar
You need to talk to Souk, the CIS Jedi master...
PCA-Chicago Region-DE Tech Coordinator-Retired
PCA-Chicago Region GingerMan DE Co-Chair-Retired
1987 Cab-under construction-Sold pending pickup
1986 911- Race/DE car-Sold
Old 09-19-2008, 06:02 PM
