Bavsport's Avatar
New Finned Aluminum Sump plate
Has anyone used this new sump plate yet? I'm wondering how well it would work?
http://www.**********.com/ShowItem/253353%20Porsche%20911%20Oil%20Drain%20Plug%20Sump %20Cover%20-%20Aluminum.aspx
Scott
Scott Sharp
83 911 SC Guards Red
95 Honda Accord V6
Old 02-25-2008, 06:41 PM
sean m's Avatar
Scott,
I got one, no noticeable difference in temp if that's what you're after.
The main reason I got it was my previous sump plate didn't have the bolt to let the oil out.......you had undo the complete plate (all 6 bolts) when you changed the oil which was a total PITA!
Other than that, it's just bling.
Sean
Sean M
'77 911S Targa Ice Green
Old 02-25-2008, 07:11 PM
dweymer's Avatar
Host sells 'em too! The aluminium resists warping better than the steel ones.
Donnie
Currently Porsche-less.....
Old 02-25-2008, 07:13 PM
Bavsport's Avatar
I was actually wondering about both. I know the aluminum would seal better, I thought it may have some cooling effect on the oil at the pickup. If it made a difference it may be cheap protection, it would definitely be cleaner.
Didn't see it here, but if I did end up getting one, I would check here first. They are a first class operation from what I see.
Scott Sharp
95 Honda Accord V6
Old 02-25-2008, 08:46 PM
Information Junky
island911's Avatar
Ya know, if you type in "aluminum sump plate" above, you'll get:
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=9144&section=ENGoil&page=3&bookmark=14&part_number=MCD-930-107-001-00B
Old 02-25-2008, 08:53 PM
9elf's Avatar
Originally Posted by sean m View Post
Scott,
Sean
Exactly what Sean said.
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan.
“Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan.
Old 02-26-2008, 12:13 AM
just something to get a little closer to raised manhole covers IMO.
206 637 4071
Old 02-26-2008, 05:31 AM
dweymer's Avatar
good point John!
Donnie
Old 02-26-2008, 06:01 AM
Bavsport's Avatar
point taken
how about the finned oil lines from elephant racing? do they make a noticable difference in cooling. I particularly like the fact that you can get all the oil out when changing the oil.
I am trying to find the most cost effective method to bring my car's temp down. It has a trombone cooler. I don't race it, so I'm not looking for something to control really high temps, just enough to keep it from getting up to 220.
Scott Sharp
95 Honda Accord V6
Old 02-26-2008, 06:34 AM
dweymer's Avatar
Switching out the trombone for a carrera fenderwell cooler should fix it. They are around 250(last time I looked) used. They require the least amount of work as they will work with the existing hard lines. You will have to run wiring and probably a relay for them if you run the fan.
D
Donnie
Old 02-26-2008, 06:40 AM
Bavsport's Avatar
Donnie,
I have thought about that too. The thing is, it looks like someone in the car's previous ownership had the car lifted using a floor jack in the wrong place and crushed the return oil line. I used the trick on youtube and posted here to open it back up, but someone posted that they wouldn't waste their time because they had to be perfect. I figure it has to be better than being pinched closed. I have several projects I'm doing while I got the car in the garage, I haven't got the car finished, so I don't know how well it works. I busted all the oil lines loose while I was there and applied anti-seize so if I was going to put the new lines on now would be the time to do it. If that didn't work out, at least I would have good lines on and then could look more into the carrera cooler.
Does that make sense?
Scott
Scott Sharp
95 Honda Accord V6
Old 02-26-2008, 07:01 AM
emac's Avatar
island911
That plate looks like the hole needs to be tapped out for the bolt??
Ernie 81 SC
Old 02-26-2008, 07:15 AM
Pete000's Avatar
Another one of those nifty items I want that no one can see...
Work to Live, don't live to work...
dweymer's Avatar
Scott,
Search here for oil line repair, Tim hancock(i think) did a very nice job repairing his. I have also cut and brazed mine. You can use copper, but should use special solder, which is why you should search for the thread.
I am sure the elephant lines are nice, but they are very expensive and since your not going to race it, standard oil lines and the carrera cooler will be fine.
Used oil lines come up from time to time here, the problem is shipping them though.
Donnie
Old 02-26-2008, 07:21 AM
Bavsport's Avatar
Thanks Donnie,
I have fixed them somewhat with the pressurize and heat method, they are not crushed closed anymore. I will start the search for a carrera cooler, they also have a carrera cooler kit at elephant racing, but I will see what comes up used. It's going to be a month or so before it gets hot here. I hear that you have to be careful buying a used oil cooler, I think I would feel better spending the extra money to start with a fresh one.
Scott
Scott Sharp
95 Honda Accord V6
Old 02-26-2008, 08:04 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
This type of sump is necessary when you change to the Turbo style pump because the screen hangs down lower than the original.
If you dont make more room for the screen, you might starve the engine.
Bob
Bob Hutson
Old 02-26-2008, 08:05 AM
GothingNC's Avatar
I have one
No leaks.
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 02-26-2008, 08:32 AM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
I have the Mainely Custom By Design one and I love it. Comes with all new hardware and gaskets.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 02-26-2008, 08:55 AM
MAGA
Tim Hancock's Avatar
Originally Posted by Bavsport View Post
Thanks Donnie,
Scott
Scott, those lines do not have to be perfectly round. I assume you got them opened up quite a bit using the torch and air pressure. If you were flirting with high temps with a smashed nearly closed line, chances are you might be fine now that you "unsmashed" them. IOW, if the lines are approximately within 75% of their original shape they will do their job. If your temps are still too high for your operating conditions, then you will need to add an oil cooler.
Cool collars, finned oil lines, finned oil sumps etc are not going to do much to significantly reduce oil temps.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 02-26-2008, 09:20 AM
Less brakes, more gas!
euro911sc's Avatar
I always thought about getting one of those so I could fix a leaking issue... but then I hit a few manhole covers in my other car and that changed my mind. I even worry about the drain bolt sometimes, but I'm not as low in the pcar. I don't think there is enough surface area to make a heat difference.
... it would definitely be cleaner.
Cleaner looking maybe for a few days... can you imagine trying to clean out all the little grooves and crevasses with a q-tip... what a PITA.
I had a weeping sump plate that had been warped around the stud holes. The bottom of my engine was always slimy and these billet parts would be nice and machined flat. Here is how I just solved (I hope) that problem the other day:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/395042-fixing-my-weeping-sump-plate.html#post3793167
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 02-26-2008, 09:28 AM
