-   -   930 Brake Caliper Part Number Check (http://forums.pelicanparts.com/porsche-911-technical-forum/424860-930-brake-caliper-part-number-check.html)
luvndasun 08-12-2008 03:04 PM
Hi,
I did a search and also checked the PET. Can somebody help me with these part numbers?
930-352-541-1R
930-352-541-0R
I think that the 1R = Front, and 0R = Rear, but I need confirmation.
Thanks!
WERK I 08-12-2008 03:39 PM
It appears to be that way.
Front
http://forums.pelicanparts.com/uploa...1218580737.jpg
Rear
http://forums.pelicanparts.com/uploa...1218580777.jpg
mede8er 08-12-2008 04:08 PM
All min are 1R's...541 outer, 542 inner.....
30mm piston rear, 38 front...:confused:
mede8er 08-12-2008 04:27 PM
From our host....
930-351-091-03-OEM Front Brake Caliper, left, 911 Turbo (1978-89), New
Brand: Genuine Porsche
$832.75
930-351-092-03-OEM Front Brake Caliper, right, 911 Turbo (1978-89), New
930-352-091-03-OEM Rear Brake Caliper, left, 911 Turbo (1978-89), New
$810.00
930-352-092-03-OEM Rear Brake Caliper, right, 911 Turbo (1978-89), New
Steve@Rennsport 08-12-2008 04:52 PM
Here are some numbers:
930 front calipers: 930.351.091.03 (L) and 930.351.092.03 (R)
930 rear calipers: 930.352.091.03 (L) and 930.352.092.03 (R)
Note the differences between front & rear caliper numbers; 351 & 352,............:) :)
mede8er 08-12-2008 05:08 PM
One of the beauties of the 930 brake is that a right can be converted to a left (or vice versa) just by flipping the outter piston housings....most likely a throwback to the old racing days when spare parts were at a premium...
djpateman 08-13-2008 07:02 AM
The original poster had the wrong idea. The numbers he posted are from rear calipers denoted by the 352 portion of the part #. Fronts are 351 part numbers as Steve says. In the third section of the part number the last digit is odd for the Left side and even for the right side (091 & 092). The 541 I'm not too sure about but might be casting numbers for the individual caliper halves.
luvndasun 08-13-2008 07:43 AM
I am an official knucklehead. I was looking at the first part number that I saw on the calipers, which is the part number that is on the outer half of the caliper. The actual part numbers for the entire caliper is kinda hard to see, it is small and towards the front of the caliper. Thanks for the help.
