joetiii's Avatar
Clutch linkage bang! then partial clutch
I was driving home last night and depressed the clutch on my 911 trans. I heard a loud clunk and could barely get it into 5th w/o grinding it. The clutch pedal did not seem to return as high as it did previously. I got it home by taking routes that did not require me to stop. Back in the garage, I couldn't get it to go into 1rst.
I havn't gotten under the car yet but I'm not sure how the clutch cable on a 911 trans. can pop out of place. Two years ago, I had the clutch pivot fork snap and that totally made the clutch inop. Is it out of the ordinary that the clutch adjuster partially comes out of whack?
joe
'69 911 E Targa - aka "RoxiE"
Old 08-23-2008, 10:42 AM
fred cook's Avatar
Partial Clutch
Check the clutch pedal roll pin. It has probably broken. Time for a pedal cluster rebuild!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 08-23-2008, 11:21 AM
What the ?
glewis80SC's Avatar
Happened to me last month, went the clutch cable route first ended up being the roll pin and the cluster needed a rebuild. It is not too technical just time consuming.
SCWDP 73
1980 SC
Harley Davidson Road King
9/11/01 FDNY/343 Never Forget!
Old 08-23-2008, 11:26 AM
joetiii's Avatar
Looks like I need to dust off Wayne's 101 projects.
joe
Old 08-23-2008, 11:41 AM
crustychief's Avatar
+1 on roll pin. might also want to replace the shaft.
Clutch adjustment problem found and repaired
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 08-23-2008, 12:22 PM
Mitch Leland's Avatar
When that happen on my "84" it was the clutch fork braking, however there was no snap... Not a good thing!
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 08-23-2008, 12:34 PM
joetiii's Avatar
ok then I have removed the pedal board, popped off the accelerator pedal linkage and have loosened the clutch cable. My problem now is that I only can get about a 1/2 turn on the cable before it binds up and can't be turned further. Any suggestions?
I've got the back end up right now, so do i release the end by the fork pivot so the cable can spin?
joe
Old 08-24-2008, 12:44 PM
