-   -   wipers not working ! (http://forums.pelicanparts.com/porsche-911-technical-forum/425696-wipers-not-working.html)
SLR 08-18-2008 05:51 AM
Was driving in the UK 2 weeks ago and the wipers stopped. First the washers stopped . I checked the fuses all ok there, there are 3 relays in the fuse box which I pulled and put back, after some time all was working but not the washers. now I'm heading for a trip to France with the car and the wipers an't working. I went the fuse rout again but nothing is there a relay some were that I have mist?
Thanks Steve.
ps, car is 1986 3.2 euro .
peppy 08-18-2008 08:04 AM
Yes, there is a relay. I think it is a PITA to get to, it is behind the fresh air blower in the trunk. Mine gave me trouble, and I just cleaned the contacts and it was ok.
mike635 08-18-2008 09:22 AM
My wipers stopped working about a month ago but I didn't sort it out until this weekend. Based on a tip found from an archive search, I looked at the 3 bulkhead connectors below the dash and sure enough - one had come loose. Plugged it back in and wipers are now back to normal. It's worth a look.
The connectors on my US '81 SC are above your left knee on a US car and are round.
mike
08porscheblue 08-18-2008 11:43 AM
Hi, I have a 1995 carrera 993 and my windshield water pump stop working. I replaced it with a new one yesterday and still not running( not pumping water but windshield wipers are both working)...When I tested the old one from the battery, it was running but I replaced it anyway with the new one...There is no clogged and the fuse are fine...Anything else what to do? Is there a relay or do I need to clean the wiperswitch terminal and where it is located? Thanks
