-   -   F/A ok at idle,, but leans out under load (http://forums.pelicanparts.com/porsche-911-technical-forum/425919-f-ok-idle-but-leans-out-under-load.html)
g rad 08-19-2008 10:06 AM
I have a SSI heat exchangers with a O2 sensor installed to gauge... on my 76 2.7.. Anytime under load,, cruising at 60- 70 mph and especially accelerating the gauge goes from 15 ish to 17 ish, the leanest number on the gauge.. F/A is fine at idle.. I'm at a loss... thanks, g rad
kuehl 08-23-2008 06:50 AM
Assuming you have an accurate wide band, you are lean.
viejopatron 08-23-2008 06:59 AM
You might have a leak on the intake side. Maybe a screw or plug fell out.
g rad 08-27-2008 08:11 PM
When I had the engine rebuilt, I used, can't remember why, a different throttle plate body... I have a 76 (my year) vacuum diagram,, so I have been changing them around,, to good effect,, with the intent of returning my original first opportunity.. at least the F/A gauge is nonfluctuating every time I accelerate or under load... Thanks for the reply......... g rad
