-   -   MFI Injector lines (http://forums.pelicanparts.com/porsche-911-technical-forum/426025-mfi-injector-lines.html)
jcge 08-19-2008 06:57 PM
MFI Injector lines
I'm gathering information to document how to rebuild (make from scratch) replacement MFI injector lines.
Material = Double wall steel bundyweld tubing (can any body confirm internal and external diameters and materials ?)
Flare form
Warren Hall Jnr (Early S Man)
posted some time back that the lines used a DIN flare
I'm assuming that this is similar to the DIN 74234 bubble flare form 'F" (see below) but haven't determined if it was the "F" or "F 180°" form - any suggestions ?? Nut and recesses would be to DIN 74233 parts 1 Nuts, and 3 Bores)
http://forums.pelicanparts.com/uploa...1219196518.gif
In both F forms - the end is finished at an angle of 115°, which provides a small amount of "crush" as it tightens against the 60° cone of the injector inlet - effecting the seal.
The difference between the F and 180° F is at the back of the flare - the 180° form has a right angle step in the tubing, versus the gentle "bubble" form of the standard F form.
Hazet, Stahlwille (#165) , Gedore etc all make flare tools to deliver these flare forms.
Any info or pics (esp closeups with caplier dimensions of the standard flare form)would be greatly appreciated.
John
Fritz Peyerl 08-19-2008 07:14 PM
MFI fuel Lines
I checked my lines and it is the "F" doppel-boerdel
The inside diameter is 2mm
Outside diameter is 6mm
the finished boerdel diameter is 8.5mm
hope this will help
Fritz
jcge 08-19-2008 07:30 PM
Thanks Fritz - appreciate your rapid response
John
jcge 08-19-2008 08:16 PM
Here's a link to TI Group's automotive division (the owners of "bundyweld tubing")
Bundyweld Tubing
Based on their product lineup, I'm assuming the wall thickness for the tube is
0.028" = 0.71mm
Can anybody confirm this spec ?
John
Fritz Peyerl 08-20-2008 06:14 AM
tubing wall thikness
0.028 inch = 0.071 12 centimeter
you are correct
