alternator nut torque setting
does anyone have the correct torque value for the 6 nuts on the alternator.
Don't know the spec, but those 6mm bolts can't stand much. An 8mm bolt torques to 18 ft-lb, IIRC. Use nyloc nuts and pull the air deflector up tight, plus just a hair.
| All times are GMT -8. The time now is 04:09 AM. |
