ZF LSD differences ?
Hello to all,
Today I get a used ZF lsd from a 915 box. After examination it has coarse splined flane inputs and 2 firiction discs per side. Is there any advantage in performance and/or value compared with the late fine spilned 1 friction disc per side 915 ZF lsd ??? Thank you ! SmileWavySmileWavy |
As long as you need the course splines, yes, the 4 disks are generally preferred over the later 2 disks.
Both are called 40%(usually) but the greater friction surface of the 4 leads to greater torque transfer. if the friction disks are worn they can be replaced. Guard plasma disks would be a good way to go there. In addition transfer torque can be influenced by the tolerances when they are set up |
Jim,
Thats an early 915 LSD. You must use the special LSD axle flanges for those and they are NLA from Porsche. What year is your car?? |
| All times are GMT -8. The time now is 04:08 AM. |
