Pierburg Fuel pump installation question
Does anybody out there have and photos of a Pieburg install? I am replacing my Bosch unit in a 70T with a 3.0 with Webers and thought I would go here first for some ideas. Thanks-Bill
Old 08-23-2008, 10:23 AM
joefrantz's Avatar
I'm not sure this will relate well to your project. My pump was originally a rear mount.
I mounted the Pierburg in front, but I didn't want to drill the aluminum (also nonstock) xmember, so I made up a bracket to suspend the pump from the steering rack.
I think 70's had a stock front mount to begin with, so I would just try to adapt something from that .
Joe
Joe Frantz
73 911 T
Old 08-23-2008, 11:33 AM
Joe did you just dead head your pump to the carbs, or did you create a T and run a line to the carbs, and a return to the tank. Thanks-Bill
Old 08-23-2008, 11:43 AM
Joe,
Very clean install. Congratulations.
Sherwood
Old 08-23-2008, 12:28 PM
joefrantz's Avatar
Thanks Sherwood.
Bill - I'm using a loop through the carbs, through a pressure regularor, and into the former FI return line. The car was originally a CIS T.
Joe
Joe Frantz
73 911 T
Old 08-23-2008, 05:35 PM
