removal of Secondary Venturi...how to...
I've been searching all morning looking for the method of removing the secondary venturi. It appears that I may need a special tool?
Old 10-04-2008, 12:28 PM
The secondary venturi slides upward after removing the top cover. The sec. venturi must be installed in the correct orientation.
Sherwood
Old 10-04-2008, 02:37 PM
Sherwood, let me rephrase, I have the tops off and I know they slide upward, but mine are not sliding upward. Is there a special tool to pull them upward?
Old 10-04-2008, 03:09 PM
Just your fingers.
You may gently grasp them with softjaw pliers as they are spring-loaded at one end and are supposed to fit nice and tight.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-04-2008, 04:10 PM
or you may have to work up one side a 1/16", then the other side--sometimes they get cocked in there and get wedged.
I've also made two loop handles out of zip-ties, since it is hard to get your fingers down the barrels and still have any leverage.
Matt
72 911T Targa - Sold
Hang up the cell phone. Put down the Latte. Ignore the kids in the back seat.
Use your blinker when you want to change lanes. AND DRIVE YOUR Fu@#!NG CAR!!
Old 10-04-2008, 04:59 PM
abit off center
cgarr's Avatar
I made a small slide puller type tool to pull them out. Just keep it straight when pulling.
______________________
Craig
G2Performance
Old 10-04-2008, 05:28 PM
Clever Craig!
Thanks to all......I got them out!
Old 10-04-2008, 07:03 PM
