shifter knob removal???
How do you get the shifter knob off an 87 911 Carrera,I cant find it in any of my books and I dont wanna break it.thanks,john
1987 911 Carrera Targa 1998 Lexus SC400 1965 Fastback Mustang 2000 Ford F350 PS Diesel Dually 2003 Yamaha FZ1 |
G50 Trans I assume.
Carefully pry up the shift pattern cap - dont break the tabs. That reveals the allen nut that needs to be removed. Then it just pulls off.
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
<insert witty title here>
Don't know if it's the same, but with my 72 shifter, the knob is only held on by a crush washer - it just pulls off, as I discovered one day at the track...
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Make Bruins Great Again
The G50 trans (`87-89) does not use a crush washer like older cars.
If you break one of the prongs on the cap you can order them from our host for less than two bucks (ask me how I know). The real expense is if you damage the leather on the shift knob while trying to pry off the cap. After that you are home free.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
a.k.a. G-man
indeed, like this.
Сидеть, ложь, Переворачиваться |
Actually, mine just unscrewed ... I just turned the knob, the bolt stayed stuck to it for whatever reason, and the whole thing came off without ever popping off the cap.
Turned myself a nice replacement wood knob ... cheap and just what I like.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
If it's the same as my G50, pop the shift patern button on the top, you will see the big bolt in there. Take that big bolt off, it's off.
Fat butt 911, 1987 |
