HELP!! Transmission question
Trying to get pressure plate and throw out bearing off tranny but it seems to be stuck any help would be appreciated!
Take the long arm off. it's under the bellhousing. Then the release fork will rotate out of the throwout bearing's groove. normally, this is done before dropping the engine and trans, so you don't have to take the 9 pressure plate bolts out.
The tranny came like this when I purchased it thanks a lot.
Well, at least all the levers are there...
Bruce |
