plug&play's Avatar
need Carrera sport cat recomendations
Hello
New owner, just got an 87 Targa and it failed the emission's test in TN. It failed with a fabspeed cat bypass but was close. Then I installed a cat that the PO gave me, it was laying around the shop and did not come out my car. With the cat it failed even worse. I took it to a mechanic and he said the cat wasn't working. He is going to try adjusting the air flow meeter to get it through the test.
I am looking for recommendations on a sport cat. Will they get you through emmissions? Do they offer the same hp benefits as a bypass? I only know of a sport cat from Fabspeed, anyone have any experience with it? Any other sport cats available?
Tony
-- 87 911 Targa (Diamond Blue Metallic) 'Boxer-2'
-- 04 BMW R1150RS (Gray & Bavarian Creme) 'Boxer-1'
Old 08-29-2008, 07:54 AM
see if a local Pelican will lend you a working cat... likely someone will have one sitting in the garage waiting for the next emission test..
a cat bypass would not pass in any case in CA.. it doesn't pass the visual.. no cat, no pass
Old 08-29-2008, 08:33 AM
The M&K pre muffler shure looks like a cat.
Can these things pass the sniff tests w/o a cat?
Old 08-29-2008, 03:55 PM
Recreational User
porschenut's Avatar
I have a GHL sport cat in addition to the GHL muffler. Sounds fantastic and passes Denver emissions easily.
Old 08-30-2008, 08:51 PM
