testing wiring harness
Is there a simply way to test the engine wiring harness? I have mine out ('88 3.2) for the rebuild and don't want to spend nearly $900(!) just to replace it if it works fine. I have been careful to avoid bending it but I'd like to know if it's working properly before I put it back in. FWIW, it apparently was working fine when I removed it. I did a search and it appears these can be rembuilt, so to speak...is this a DIY project? I'm fine with mechanicals but electronics are a bit of a mystery. Would I just test continuity or should I check resistance? That's probably the extent of my abilities, electrically speaking.
TIA
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 08-29-2008, 06:58 AM
When you test a harness, it's mainly continuity you check. If you use a typical multimeter, you'll see the resistance anyway. A physical inspection of the harness and connectors (looking for damaged insulation/wrapping, corrosion, bent pins, etc.) is also useful. Get a meter and read the instruction book. It's pretty basic.
JR
Old 08-29-2008, 07:03 AM
