AWD system
Anyone know how similar the AWD system used in the 964 is to the one used in the Vanagon Synchro (bus)?
Randy,
As far as I know the two are quite different. There are two different synchros though. VW had the... Quantum wagon which was the exact awd system from an audi 4000, but the vanagon was true 4x4 4wd, not AWD. C4s were the first and only all mechancial awd Porsche made, but they had TCS, and diffs, etc... which I don't think the vanagons ever had. The vanagon was more like a 4wd truck complete with "low gear" for slow speed off road use. |
Vanagon uses visco clutch between rear and front wheels just like 964, 993 and 996 did. Note that first year of 964 C4 had completely different system derived from 959: a computer operated clutch between front and rear. System proved expensive and cumbersome and was later replaced by visco unit which hang on until 997. As far as I know, 997 is going to get a Haldex computer-operated clutch for C4 and Turbo.
That being said, neither C4 or Vanagon ever had "real" 4WD with center differential. They only had locked middle axle with power feed to front going trough some "slippage" component. Usually a visco diff or in rare cases (964C4 89', 959, 997) a computer-operated clutch. Here's more info on Vanagon: http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind9604&L=vanagon&D=0&P=99494 |
997s are still viscous... the 998s are getting the haldex though, which... i'm not too happy about.
I'll bow to Goran's knowledge on the vanagon though. |
964 used a unique transmission w/ twin parallel output shafts and 2 hydraulically controlled clutch type diffs, one longitudinal and one transverse on the rear wheels the hydraulic pressure is varied and controlled by a computer w/ long. & transverse accelerometer inputs as well as wheel speed inputs from the abs wheel sensors, std f/r split is 31/69 but it can be varied the 993/996 e ts AWD is just a simple non computer controlled device that can be simple removed to convert to 2WD, not so w/ the 964 which is a very complicated integrated system. I haven't a clue about the VW systems. |
Are all 964's equipped with this computerized clutch or was it really there only for one year? Thanx. |
Well I don't see the problem with Haldex. It's virtually the same setup as with visco, with a difference that it can be locked in a very short amount of time where visco diff need some time to shear/heat up. I had a pleasure to drive SAAB 9-3 Turbo X equipped with new generation Haldex clutch and it worked flawlessly. It is set up so it locks in pre-emtive fashion w/o computer waiting for a wheel to slip first. |
later Audis and Porsche from 993 on use the viscus silicon center diff and a standard lsd or electronic ABD rear diff(sometimes both in the same trans). the 964 trans is unique to that model and not interchangeable w/ others or changeable to 2wd mode, the 993 up trans can be swapped to other chassis or changed to 2wd w/o much fuss. |
OK, but I fail to see similarities with Audi V8? Audi V8 (up to 1994) had a Torsen differential in the middle, Torsen in the back and open differential in front. UrS4 (1992-1994) had same layout but rear differential was open one that could be fully locked on demand (but it unlocked automatically above 15mph). Reason I know this is that I've just bought a V8 Torsen rear diff for my UrS4 (so I can swap in instead of old open one in the rear). As far as I understand, 964 had basically same layout as 993 (no middle differential) except that there was electrically operated clutch instead of visco clutch between the axles. Audi Quattro (older ones) had a mechanical differential between axles but 964 had no middle differential at all but a clutch between pinion drive between front and rear differential. Regards, |
Again I don't understand the reluctance of some people to believe factual info. The 964 and 993 are totally different AWD systems, do some research, please. |
Dear Bill. I just did some research, at least for Audi V8 -90 3.6L. It doesn't have any sort of space-cadet mumbo-jumbo computer operated clutch differential. It has ordinary plain-vanila Torsen diff in the middle (just like all other Quattro cars made after it) and rear Torsen diff (which was in later cars replaced by open diff that was locked 100% with a vacuum-operated fork when button is pressed and unlocked automatically as soon as speed was above 15mph). Take a look here: http://www.vagcat.com/epc/cat/au/V8/1990/90/52/997727/ Article number for center differential used in V8Q -90 3.6 6-speed manual is 01E409751F. 5-speed manual used 016409751A. http://forums.pelicanparts.com/uploa...1220129040.jpg Regards, Goran |
OK, I did more research.
It turns out that auto equipped Audi V8Q didn't have Torsen center diff but open center differential that was lockable by computer. Manual tranny V8Q had indeed Torsen center diff. So we were both right and both wrong. Further, it seems that 964C4 didn't have center diff at all, but fixed-split system with clutch in-between. So to round it off, it seems that 993,996 and 997 have same system (fixed split) but electrically operated clutch is replaced by viscous device. 998 will replace viscous device back to electronically lockable clutch again, this time made by Haldex. Quote:
Regards, |
As far as I know there was no manual trans for the V8s in '90 maybe that came later and maybe the used torsen ctr diffs I had a '91 200TQ w/ manual that had a torsen ctr diff.
All 964('89 -94) C4 used the G64.00/.01 or /.02 trans it is significantly different from the 964 G50 or later 993 G50 which has an input shaft parallel to the output shaft, on a 993C$ the forward end of the output shaft is splined and a passively activated silicon fluid coupling sends power to the front diff . The fuluid coupling can be removed to convert to 2wd w/ no adverse effects on the trans. A new cover is used and the frt diff is also removed. The 964 G64 on the other hand has a hollow output shaft, w/ another shaft running concentricly on roller bearings inside of it. The variable computer controlled clutch pack ctr diff is connected to the outer shaft, power is variably directed to the front diff. The inner shaft carries power to the normal rear diff. 964 cutaway of drivetrain http://forums.pelicanparts.com/uploa...1220132842.jpg 964 clutch pack ctr diff http://forums.pelicanparts.com/uploa...1220132931.jpg 964 G64 shafts #26 is the hollow outer # 23 is the inner http://forums.pelicanparts.com/uploa...1220132962.jpg 993 G64 & g50 shafts http://forums.pelicanparts.com/uploa...1220133428.jpg 993 ctr diff http://forums.pelicanparts.com/uploa...1220133455.jpg |
the 993 system is fixed 50/50 but again the viscous clutch varies power to the front diff, the differential function is 100% in the viscous clutch 993 G64 http://forums.pelicanparts.com/uploa...1220134744.jpg |
Here is a photo of the LSD from the 964
http://blobs.autobahnparts.com/media...64462590000000 http://blobs.autobahnparts.com/media...64520270000000 |
| All times are GMT -8. The time now is 09:57 PM. |
