WTB Zenith 40 TIN parts
Resurrecting 911 from long term storage. Much crud in zeniths. upon dissasembly, need one of each so far;
porsche part number
901 108 940 00 air correction jet, marked 195
911 100 935 00 accel pump inlet valve
911 100 925 00 emulsion tube.
The jet and inlet valve crumbled upon removal and I was able to get the remains out with an easy out.
The tube was stuck in the body of the carb and used the same easy out to remove it.
I have only taken the right side apart and would apprecaite any tips on avoiding this issue as the right side is torn down. Gas tank is now clean.
Many Thanks
Wray
Old 09-01-2008, 04:05 PM
