<insert witty title here>
Christien's Avatar
Can anyone identify these loose wires in my engine bay?
I have no idea what any of these are for, except I believe the thick flat ones are for my rear window defrost, which has been disconnected since I swapped out the decklid for the ducktail. Some may be for wiring for the license plate lights, which were also disconnected at the same time, and I didn't take note at the time of what went where. However there seem to be far more than just those things here.
Obviously the short green and yellow what is a ground, but what for? The circle-end wire that's tied in a bunch is connected into the wiring plug that goes in behind the fuse panel. I know that's a lousy description, sorry
Thanks!
Chris
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 09-01-2008, 02:15 PM
Fritz Peyerl's Avatar
odd wires
let's try and if I am wrong, some body will tell us very shortly
ground wire yellow/green god knows what the PO had hooked up
the grounding strap looks like is for the engine lid
the bundle of 3 red wires could be for the rear window defogger, if you have no defogger, the rear window was replaced
Old 09-01-2008, 02:25 PM
Christien's Avatar
I do have a rear defogger, and it worked fine before I disconnected it, but as I said, I didn't mark which wires were for it.
Old 09-01-2008, 02:32 PM
Danny_Ocean's Avatar
That's easy to test. Put a light on them and click on the rear-window defroster switch.
The big ground straps are for the decklid. Yank 'em and put 'em in a box.
Old 09-01-2008, 03:02 PM
dshepp806's Avatar
When done with those wires, do get them sealed up/isolated nicely.
They look to be RW DF....as mentioned,..hook your meter up to it and look for 12VDC with the RWDF switch actuated...
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-01-2008, 03:21 PM
