Sneakin' 'Bout
Batteries for 1971 911
Hi, I need 2 new batteries for a 1971 911 E, Im in the san francisco bay area. Can someone point me to a dealer? Interstate no longer carries the ones I bought 10 years ago. thanks
------------------------------ 1971 911E Canary Yellow w/Mahle wheels and AC |
For a Long Nose, you have several choises:
Replace your twin batteries with a single Optima on its side. You will need to fabricate a hold down and fool with your leads. Not hard if you have any mechanical competence. I used a flat braided ground lead and placed the negative (ground) end inside the battery box. I bought my red top at Costco and I think it is a Model 75/25 or a 34/78; A pair of Miata Batteries; or A pair of Sonnenschein DF75 (A512 /40 A) gel cells - www.batterysales.com (exact fit as well).
I put 2 Deka batteries in mine. If you have any questions, let me know.
Deka - Another Dual Battery Option
Craig '69 911T |
I went with one optima, i ad to fab up a hold down and mount the battery on its side. Check out rennline for other optons
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Interstate still supplies the 911U battery, some of the distributors chose not to carry them. You can try a different distributor.
'69 911E 2.7MFI ;996TT;987.2 CaymanS '71 Volvo P1800E wife's; AMG SLK wife's '71 Volvo race car 944S; 986S ; 734WHP drift car (son's) |
(the shotguns)
i went with the sonnenshnoozensteinmeisterbrau just to avoid the fabrication bull****. actually was considering factory weight distribution as well.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
FYI the Garner NC Interstate warehouse had the U911 batteries for $103.95 as of 6/16/2009. I had to call Interstate, get a person, and they connected me to the local warehouse...
I just put a new Interstate in my '72. They're still around and work just fine.
Richard |
Sneakin' 'Bout
Hmm, I'll give them a call!
