86 Carrera Coupe
janz's Avatar
Location: Holyoke, Massachusetts (western end of state)
Blue smoke on startup sometimes
Sometimes after sitting for a while (a week or more) my 86 911 will smoke on startup and sometimes not a hint of blue smoke. After driving and it doesn't matter how long or short it sometimes smokes at startup and sometimes non at all. When it does smoke it clears within 5-10 seconds. Is this normal? Oil consumpsion is less than a quart every 1,000 miles. Making me crazy thinking its time for engine work, but it starts right up, runs great, strong and idles very nice. Car has 144,000 but have no records before 141,000. Engine is clean and looks to have been worked on/clean with no leaks. I suppose I'll hear about the leak down tests but it just runs so good i don't want to jinx it. BTW theres no valve noise either (lifter noise). I have changed oil and filter, fuel filter, new plugs, cap and rotor, air filter, tranny fluid and brake fluid when I got it. When I check the oil after engine is warm/hot it reads right in between the lines durring idle. Idle does change when I remove the oil filler cap.
Old 11-09-2008, 02:00 PM
Mo money = mo parts
My '86 smokes 'sometimes' on start up too. Typically, it's associated with how long it sat prior to running last. Unfortunately, my consumption is closer to 1 quart per 450 to 500 miles. I have a valve guide, and possibly ring, project in my near future.
My understanding is that brief smoke at start-up is an common attribute of boxer engines. I would let consumption be your guide. At 1,000 miles per quart, you have no related worries. There are many people that use more oil than you after a rebuild.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 11-09-2008, 02:10 PM
Tsunamiboy's Avatar
Let your Porsche run at idle for a short while before shutting off. I believe it makes a difference in the puff factor.
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 11-09-2008, 03:09 PM
old man neri's Avatar
What weight of oil are you using?
Old 11-09-2008, 03:47 PM
I would not be concerned until oil consumption reaches 800 miles/qt.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-09-2008, 04:27 PM
86 Carrera Coupe
janz's Avatar
Using 10w 40w castrol gtx
Old 11-09-2008, 04:31 PM
I wouldn't worry too much about it.
If you see smoke on acceleration or deceleration then you might have a problem.
I have an '86 with 204K on it. I use a worrying 6-700 miles/quart yet it NEVER smokes on start-up nor when I drive it hard. It has good power, etc.
Go figure.
1986 Targa
1968 MGB (2)
Old 11-09-2008, 04:49 PM
RETIRED
Joe Bob's Avatar
Welcome to the club.....run the oil a bit low and avoid steep driveways unless you have an incredible cool factor and can survive the subsequent oil fog from the tail pipe.
BTDT
2012 ML350 3.0 Turbo Diesel
Old 11-09-2008, 04:51 PM
86 Carrera Coupe
janz's Avatar
Was sorta hoping that would be the case but just wanted to check and see what others were experiencing. Good news to me that I can wait another year before i tear into the engine. Got some other small issues to deal with first but have been knocking them off pretty good. really do love driving my 911 to bad there were'nt more nice days up here in New England. Thanks to all who took the time to answer.
Old 11-10-2008, 09:06 AM
