Throw it on the ground!
Repair vs Replacement options for this part?
PN 930.110.328.05 Pipeline. Replacement cost is $138. Will be sending my carerra fuel lines to Amazon Hose to be rebuild. Is this a part that they can rebuild vs replace? The rubber portion of this line is cracked. Part #24 here:
Mark
1987 911 Coupe
Granite Green Metallic
Happy Birthday to the Ground:
http://www.funnyordie.com/videos/e4e2187156/andy-samberg-i-threw-it-on-the-ground
Old 09-05-2008, 05:03 AM
Friend of Warren
Common problem. It is just a vacuum line. I got some of that self sealing rubber tape and just wrapped it around the cracked rubber. Going on 5 years and it is still working just fine.
Kurt
2003 Boxster S, 1991 BMW 318is
'93 Ducati 900SS, '76 BMW R75/6, '73 350 Honda Scrambler, 2003 SV650 Track bike
Gone, but not forgotten: '86 Carrera, '72 911E, 2001 Boxster
Old 09-05-2008, 05:05 AM
Just what I wanted to hear. Not familiar with the tape. Source/brand/link?
Thanks!
Mark
1987 911 Coupe
Old 09-05-2008, 05:20 AM
Send a message via Yahoo to chris.817
http://www.ertape.com/. Fantastic stuff.
Chris
________________
87 Carrera Coupe - Guards Red on black
00 Carrera Cab - White on Navy
86 951 - India Red on black - Sold
Old 09-05-2008, 06:28 AM
gtc gtc is offline
abides.
gtc's Avatar
I just noticed a few days ago that I have the same problem. Thanks for asking the question, and for the answers!
Graham
1984 Carrera Targa
Old 09-05-2008, 08:20 AM
Mark,
I picked up several rolls of this stuff at the Atlanta Boat Show. They were demonstrating how well it worked. I can give you as much as you need to fix the job. Drop me an email.
By the way, the 911 is still in the garage on blocks and one day soon I will get to those fittings on the AC hose!!
Bob
73.5T
Old 09-05-2008, 08:35 AM
wonder if the light grey plastic part is cracked underneath.. I guess you could see if that can be ordered... or make a metal version of the light gray plastic part. Of course you also need the tube with short hose part... but as mentioned above a good taping job will work.. that's my not really needed 0.02
Old 09-05-2008, 08:38 AM
I've never heard of this stuff before. Thanks for the link.
Bob, I'll shoot you an email.
Mark
1987 911 Coupe
Old 09-05-2008, 01:30 PM
It's really amazing stuff. The owner of this company is a sailing enthusiast and sponsored my neighbor in a race to Bermuda. Fortunately I got several free rolls
Chris
________________
Old 09-05-2008, 01:45 PM
Is this the same stuff? Found this searching ebay.....looks like Ace carries a private label version at $6.95 roll.
Specs:
1" x 16'
100 PSI maximum pressure
Emergency repair tape
For water carrying plastic & rubber pipe
0-212 deg. F range
Fuses with no chemical adhesive
EDIT: Specs not the same....ER Tape is rated 300 PSI and 200 degrees (C) 398(F) and can't tell from the pkg if it is silicon.
Mark
1987 911 Coupe
Old 09-10-2008, 03:31 AM
a couple inches of shrink tubing and a heat gun works well and looks almost factory.
206 637 4071
Old 09-10-2008, 04:32 AM
great item to have in car carried tool box... hope they have it at my Ace store.
Old 09-10-2008, 08:23 AM
Definitely not the same stuff. I highly recommend the ER Tape. I had heard it would be sold at Home Depot but I cannot verify that.
Chris
________________
Old 09-10-2008, 08:46 AM
I just contacted ER Tape and they sell it by the case, minimum quantity--$108 for 24 rolls, 12 black and 12 red. It sounds useful enough that I'm going to buy a case. I'll ask them if Home Depot carries it, but they didn't say anything about that as an option.
So if anybody wants a box or more--two rolls to a box, I'll sell 'em at cost plus shipping--lemme know. Not via here, not via those damn "private messages" but an e-mail to me at stephwilkinson@verizon.net. First come, first served.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 09-10-2008, 01:28 PM
Ouch. Certainly well worth the per box price but that's a big qty. I checked and I'm down to two rolls so I'll likely take you up on your offer Steve.
I've also dropped my acquaintance a line to see if he is still in touch with these folks and maybe I can get a better deal somehow if anyone is interested.
Wayne should sell it...
Chris
________________
Old 09-10-2008, 05:42 PM
fred cook's Avatar
Hose repair
Cut off the crimp with a dremel cut off wheel, replace the hose and recrimp using an oil line metal crimp. Your local NAPA dealer should have a crimping tool. Cost should be a dollar or so for the hose and about $2 for the crimp. They might not even charge to do the crimping.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 09-11-2008, 11:10 AM
Repaired using the self-fusing silicon tape from Ace Hardware. Great stuff!
Mark
1987 911 Coupe
Old 11-30-2008, 02:13 PM
heiliges blechle!
I buzzed that metal shell off with a dremel and found a rubber fitting at Auto Zone that fit perfectly between the gray plastic end and the newly exposed copper end. I think the part was maybe 4 or 5 bucks.
'84 M491 '07 Silverado
'75 Suzuki GT550 2-stroke triple
'02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train
Old 11-30-2008, 02:48 PM
good thread - I'll keep this in mind rather than panic and buy a high price part right away
Old 11-30-2008, 05:00 PM
Update: Was noodling around the engine bay today and noticed that my silicon tape repair looked funny (odd shape). Touched the tape and it is all gooey. Apparently the cheaper Ace Hardware version of E-Tape does not hold up to high temps of the engine bay. I will have to redo the repair. I had an unstable/ intermittent high idle condition last week for a couple of days that has self corrected itself - wonder if it was related to a vacuum leak here??? I may try John Walker's recommendation of heat shrink tubing.
Mark
1987 911 Coupe
Old 07-24-2011, 11:19 AM
