-   -   how do I find out if my 84 has front or rear oil cooler (http://forums.pelicanparts.com/porsche-911-technical-forum/428850-how-do-i-find-out-if-my-84-has-front-rear-oil-cooler.html)
WIL84911 09-05-2008 12:09 PM
need this info for installing SSI's. I'm guessing my 84 has rear oil cooler but not sure.
TroyGT 09-05-2008 12:22 PM
If it's the original engine then yes... the big Z shaped rubber hose located under the right rear of the car has one end connected to the oil cooler and the other end to the oil tank.
-Troy
tcar 09-05-2008 12:36 PM
Stock it has both.
Rear, on top of the engine on the R side.
Front, in front of the RF wheel.
SCrescue 09-05-2008 01:43 PM
If you're installing SSI's, the oil cooler lines need to be backdated to pre-'75 configuration. You will have to replace the two lines currently on your car with the two lines in the attached photo. Hope this helps.
Mike...:cool:
http://forums.pelicanparts.com/uploa...1220651019.jpg
WIL84911 09-21-2008 03:17 PM
Thanks! Sorry for the delay.
