The Puff.
Mr.Puff's Avatar
Oh great, one of my oil lines is crushed :(.
The outside oil line on the right side of the car leading to the oil cooler in the fender, has been crushed (I think by the PO's mechanic) .
Do you guys suggest getting the Elephant Racing finned lines? Can I just replace with braided lines instead of hard ones?
Thanks,
John
'70 CT1B
'11 GTS 300 Super
Old 09-06-2008, 10:35 PM
Speedo959's Avatar
There was a thread recently where a guy plugged one end and pumped up the line with 100psi or so of compressed air. He then heated the crushed area with a torch. The air pressure pushed it back into shape. There is a thread here with pictures somewhere.
70 911T
71 914
89 BMW R100GS
Old 09-06-2008, 11:05 PM
The Puff.
Mr.Puff's Avatar
Nice, that trick can save me some $$.
Thanks.
'70 CT1B
'11 GTS 300 Super
Old 09-06-2008, 11:07 PM
slodave's Avatar
Post a pic. I have a crushed line and I don't see any problems - even on the track. I have read most of the debates and the fixes and one day I will try to fix mine, but for now, I just make sure to keep an eye out for any changes in temps.
Old 09-06-2008, 11:13 PM
The Puff.
Mr.Puff's Avatar
My car gets pretty hot. The dent is right before the bend from the straight portion upwards into the wheel well. It sucks .
'70 CT1B
'11 GTS 300 Super
Old 09-06-2008, 11:15 PM
slodave's Avatar
What is "pretty hot"?
Old 09-06-2008, 11:16 PM
The Puff.
Mr.Puff's Avatar
Just south of the second white line, the engine gets caught in this high rev cycle. Sometimes the revs bob up and down. I think it has something to do with a vacuum leak.
'70 CT1B
'11 GTS 300 Super
Old 09-06-2008, 11:44 PM
slodave's Avatar
So right under the 9 o'clock position? If this is during daily driving, then it's seems a little too hot.
Old 09-06-2008, 11:48 PM
The Puff.
Mr.Puff's Avatar
Yup, daily driving. The front oil cooler seems to have a bunch of rocks and dirt in it also, plus it has oil/road grime built up around the fittings. Looks like I need to replace (or fix) that line and maybe even change the cooler out.
'70 CT1B
'11 GTS 300 Super
Old 09-06-2008, 11:56 PM
slodave's Avatar
Clean the cooler and don't get rid of it! It's special to the '84.
Old 09-07-2008, 12:03 AM
The Puff.
Mr.Puff's Avatar
I noticed that it wasn't a newer fin cooler or an older trombone one. Didn't know that it was an '84 thing.
Thanks for the help,
John
'70 CT1B
'11 GTS 300 Super
Old 09-07-2008, 12:05 AM
slodave's Avatar
First half '85 or so, have them as well.
BTW, I read your other thread on the oil, leak. It may be because of sitting for a period. I fixed all my leaks last summer, then recently, noticed that I would get a few drops after driving for a few hours, after the car had been sitting for a week. if I drive the car for a few days, it disappears again. I wouldn't worry about it either.
Dave
Old 09-07-2008, 12:11 AM
The Puff.
Mr.Puff's Avatar
Good news! When I purchased the car it was losing about a quart every 500 miles, or so. On my first oil change since owning the car, I found that the drain plug was torqued down so much I had to use a hydraulic jack to get it off. The thing was also missing a washer. This small oil leak is nothing compared to that.
--John
'70 CT1B
'11 GTS 300 Super
Old 09-07-2008, 12:19 AM
After the next project
x98boardwell's Avatar
Option
Check out this thread where I had the same problem. There are pictures and a few different options for you. I also included the part numbers for the factory lines.
Replace oil pipe to trombone??
I ended up purchasing my line from the dealer which was less expensive than the Elephant Racing line and no shipping.
Best of luck,
Bryan
Old 09-07-2008, 08:10 AM
RETIRED
Joe Bob's Avatar
Try pulling the line and heating it with MAPP gas and then tapping it with a metal working hammer. Sometimes they will pop back into shape.
2012 ML350 3.0 Turbo Diesel
Old 09-07-2008, 09:12 AM
