tonypai's Avatar
Sway Bar Mounts
Hello All
Does anyone make pre fab sway bar mounts? Mine are about to go and rather than make new ones from scratch, it'd be easier to weld on a ready made mount.
It's for a 1981 RoW.
Tony
2001 Suburban - Tow Vehicle
2000 Miata - Race Car
1996 993 Carrera - Daily Driver
1981 911 SC RoW - Wannabe Race Car
Old 09-08-2008, 11:49 AM
At the track = great day
ChkbookMechanic's Avatar
I know the host (PP) sells different sway bar mounts. Do you want something like this (the WVO-RARB)?
Lane
2011 Volkswagen Jetta SportWagen TDI
Looking for another sports car..
Old 09-08-2008, 12:00 PM
tonypai's Avatar
Perfect! Let me see if the mechanic can use this.
Old 09-08-2008, 12:06 PM
Originally Posted by tonypai View Post
Hello All
Tony
Rear sway bar mount?
The factory mounts are of two types. I believe the early mount is superseded by the current HD mount. The WEVO part is stronger, especially if used with a larger than factory sway bar. Either one can be reinforced with additional metal (in the archives).
Sherwood
Old 09-09-2008, 01:51 AM
3.2 CAB's Avatar
A very small amount of 1/4" structural steel plate, and channel, can make an almost bullet proof set of mounts. I rebuilt mine a few years back, and they show no signs of any type of stress related wear, nor does the tub area, that I reinforced at the same time. It does not do a lot of good to have very strong mounts, just welded to a weak area of the tub. Total cost was basically zip, being I always have those types of materials on hand, but if I had to calculate what the actual cost was for the materials, it probably would have been about $7.00 to $9.00 Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 09-09-2008, 06:13 AM
