Has anyone used these 3 point belts before for the rear seats?
Has anyone used these brand seatbelts before? I'm ungrading my rear belts to 3 point belts. The prices seem pretty competitive.
http://www.gotbelts.com/products.html http://www.seatbeltsplus.com/
86 Garnet Red Cabriolet |
Keep us updated. I have a Carrera cab that I would also need an update of the rears to 3 point belts for my 9 year old. I'm afraid the "cab" will make it more of a challenge.
95 Carrera 4 Black/Black Coupe, Row M030, Bilstein HD Past - 89 911 3.2 silver cab |
you see Arthur...
I would be interested to know if anyone has used wither of these as well. Its time for me to add 3 points to the rear as well.
J 82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat 06 Cayenne S 00 ML 55 AMG Santa Cruz Bullit |
Update on rear seat belt install
![]() ![]() ![]() Here is an update on the seatbelt install. The kit seems to be pretty nice quality. I opted for the non-retractable belts because the belt spool for the retractable system was 4" long and would hang over the edge of my rear deck. The non-retractable belt fit perfectly. I also think that is is safer for booster seats if you have kids. Install took about 20 minutes. I replaced all of the factory bolts 7/16 fine thread grade 8 bolts. Cab Owners..Please note though.... These belts will work fine only with the top up since the top foldsdown behind the seats. I am working on a way to make it work with the top down. My idea is to mount eye bolts on the deck. This would allow me to drop the top and then reconnect the belts over the top of the folded canvas through the unzipped window. I'll let you know how that works out.
