-   -   Doumb Spark Plug Question for Early 911 (http://forums.pelicanparts.com/porsche-911-technical-forum/429769-doumb-spark-plug-question-early-911-a.html)
HarryD 09-10-2008 07:25 PM
I went to order a set of plugs for my stock 1973.3 (CIS) 911T. In the past I have used Bosch W5DC plugs with good sucess but decided to try the NGK's.
On speaking to the fellow on the order desk, he told me that he thought they were better and I should give them a try. I said ok and they shipped me a set of NGK BP5ES plugs.
Looking at the NGK Web site, I am now confused if the correct plug was selected. This APPEARS to be a much hotter plug than what am am currently using.
Anyone have any comments about this?
Thanks!
Flieger 09-10-2008 08:11 PM
I believe Bosch and NGK heat ranges are numbered in opposite directions. Bosch get hotter with higher number, NGK get colder with higher number.
Steve@Rennsport 09-10-2008 08:14 PM
Thanks!
Harry,
The NGK 5's are too hot for your car. I would use 6's.
HarryD 09-10-2008 08:27 PM
Steve,
That's what I was afraid of.
snbush67 09-10-2008 11:38 PM
The NGK number is in relation to its heat dissipation capability, so the higher the number then the lower CHT. Looks like you already figured this out.SmileWavy
rothaus 02-01-2009 06:59 PM
I was looking what tyle of plugs for my '71 911T and at the NKG site the
Standard is BP7ES and the
Iridium IX is BPR7EIX
http://www.ngksparkplugs.com/part_finder/car_truck_suv/results.asp
The same showed also for the '73
I hope these links work.
T77911S 02-02-2009 04:56 AM
BPR7's in my 77. i just looked at them yesterday. they looked very good.
