Need help: Wheel/rim repair expert
I had the misfortune of hitting a curb after loosing control (kicking myself as I have been wanting to change these lousy tires for a while).
My problem is that this specific 16” BBS wheel is no longer available, it may never have been available in the U.S. as the car was purchased in Europe. Can anybody recommend a rim/wheel repair expert who does not shy away from a challenge… The damage is large but it seems that an expert should be able to braze/weld in a piece. (see picture). Any tips are appreciated. ![]()
Anthony Vanderlinden ---------------------------- 1987 Porsche 911 1979 BMW 635Csi Euro 1926 FN 1300 |
MBruns for President
Get a new wheel - they are available - I just sold a whole set of these a few years ago for $600. Do not try and fix that - too much material.
I'd try one of the parting houses, depending on where you are located
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
You need to check your suspension too - that looks like a major hit
These I sold a year or so ago -
I agree with the above, get a new wheel.
I do not think you can just patch that chunk.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
It is not an easy find however, none of the places I have contacted had it... if anybody knows a repair facility, that would be a solution until I can locate a replacement. Right now I can not drive it...
I am sure that I have some of them.Check width and ET and I will check my stash.
It will not be costly but the shipping might will be... |
Thanks a million, I will check all the specs in the morning and get back with you.
Drive with spare installed, till replaced???????
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
That is good for emergency, drives / handles odd... it is still a full size tire but different size and smaller rim.
I will try to add more details later but this is what I could find on the wheel: -- 8J16 H2 -- 223 ET 24 -- KBA 40646 or 40545 (very difficult to read) The back spacing is about 138mm. the offset is about 12.5mm. Keep in mind that we did these measurements in garage with poor lights and rubber was still on the rim. I think it is very close if not accurate. I hope to hear back from you!
