porsche8777's Avatar
Valvioline VR-1 Oil
I switched to Brad Penn in my 83 from dino oil that the PO used which was Kendall GT-1. Since the BP is part syn I am getting a little weeping that was not there before. No real leaks and no oil spots on the floor just damp. I called Valvoline and they told me that their VR-1 Racing oil that is the Street Legal oil has 1300 PPM ZDDP. I ask a second time and was assured they were talking about the VR-1 oil at the local parts house. Since this meets or exceeds the spec for ZDDP I am considering switching back to the dino juice because of the seepage with the syn in the old engine.
Old 09-12-2008, 05:12 AM
I use the VR-1 in my 82SC and in my MGB. The MG forum has talked and talked and talked about oil and ZDDP specs and many have decided to go VR-1 also.
82 911SC
74 MGB
97 Land Rover Discovery
Old 09-12-2008, 06:53 AM
walt's Avatar
Is VR-1 one of the low detergent oils that requires more frequent oil changes? What's the SAE rating on the bottle?
Walt
82SC 3.0
81SC 3.6
Old 09-12-2008, 07:19 AM
mca mca is offline
mca's Avatar
I use VR-1 20/50 Racing Oil as well.
The "not-street legal" version is much more expensive but still available if you have NAPA order it for you. I think this version is even better?
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 09-12-2008, 08:27 AM
abit off center
cgarr's Avatar
What makes it "not street legal"?
______________________
Craig
G2Performance
Old 09-12-2008, 08:32 AM
IROC's Avatar
Too much ZDDP. probably.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 09-12-2008, 08:35 AM
You can get it in 20-50 as well as 40 and 50 single weight that I know of. The not street legal is pretty low detergent while the street legal is for longer oil change intervals. My issue isn't cost but going back to dino to get rid of the oil seepage.
83 SC CAB
98 M3
87 944S
Old 09-12-2008, 08:46 AM
I just switched to the VR-1 20W50 from the previous owner's choice of a lightweight Mobil 1 (can't remember the viscosity) and the leaks I had have pretty much stopped altogether.
Tim in MD
'86 911 Carrera
Ex-'74 914, '00 Carrera, '03 C4S, '15 Macan S
Old 09-12-2008, 08:58 AM
I have been using it all summer long. Change it at 3k miles and all is well.
rockers seem to quiet down a bit . But then again the car seems faster after waxing it also
Silver 1980SC Euro coupe
Old 09-12-2008, 09:23 AM
