-   -   Headlight Dimmer/Turn Signal Switch (http://forums.pelicanparts.com/porsche-911-technical-forum/430022-headlight-dimmer-turn-signal-switch.html)
Daviboy 09-12-2008 01:17 AM
Guys,
Seems my headlight dimmer switch is on the Fritz, I tried it a few days ago and some smoke poured out the housing so immediately turned it off. Seems I need to replace entire switch and lever, can anyone who has done this tell me if P/N 911-613-305-01-M78 is correct for an 82 SC? Thx
Davy
Bill Verburg 09-12-2008 05:13 AM
yes, that is the correct part. You might also want to consider installing headlight relays. The reason those switches fail is that the full current from the headlights is going through it. W/ a relay only the small control current is going through.
Joe V 09-12-2008 05:37 AM
Daviboy,
If yours if fried, I've got a used one available out of an '84 Carrera.
I bought a new one before learning how to fix my old one on this forum.
Nine9six 09-12-2008 10:22 AM
A good used stalk at the right price would be welcomed in lieu of a pricey new one ($135.00)
+1 on installing a relay kit to save future immenent replacements.
I purchased a relay kit provide on this forum by Marcus Sucro. Do a search on "Sucro relay" and you should find what you need at a very reasonable price of $25 for the kit. The installation instructions are flawless.
HTH,
JWest 09-12-2008 11:01 AM
Support Pelican:
Headlight Relay
Daviboy 09-13-2008 01:39 AM
Originally Posted by Joe V (Post 4176176)
Daviboy,
Joe,
Thanks for the offer but I really want to go for a new part, it is already in my $960 project list along with the relay.
Davy
mrbill914 10-05-2008 04:15 PM
Daviboy,
I need one for my 75 911s...think this will work? Bill
AtomicDog 10-05-2008 05:20 PM
Daviboy posted:
Too bad this only works on UK cars...
http://forums.pelicanparts.com/uploa...1223252310.jpg
'cause you need to get that smoke back in!
Sorry, been looking for an excuse to use that pic.
Chris
