-   -   AAR Question (http://forums.pelicanparts.com/porsche-911-technical-forum/430292-aar-question.html)
jmshepard 09-13-2008 06:56 PM
AAR Question
Does the 12vDC source to the AAR provide continuous current as long as the engine is running? I can't find any reference that indicates the power for the AAR is on a time limit.
Thanks,
Jim S.
boyt911sc 09-13-2008 07:27 PM
Auxiliary Air Regulator.......
Jim S.,
The AAR, WUR, thermovalve, and FP for SC's are all getting power from terminal #30 (FP relay socket). When the FP is energized, others are also energized at the same time. Refer to wiring diagram/s and it will help you understand the concept. HTH.
Tony
jmshepard 09-13-2008 07:31 PM
If I'm understanding the wiring-
As long as the fuel pump is energized, power is applied to the AAR. Is this a correct statement?
Thanks,
Jim S.
boyt911sc 09-13-2008 09:31 PM
The answer is......
Thanks,
Jim S.
Yes! You're indeed correct.
Tony
