Question HELP-- 1988 911 Flatens out at 4500 rpm
I am the recent new owner of a 1988 911 CE with the 3.2 with 105,000 original miles. I've recently noticed some very subtle "missing" characteristics throughout the power band, but when I hit 4500 RPMs it is almost as if a governor kicks in and the there is a flattening of acceleration. I can push the car beyond the 4500 RPMs, but something is still amiss. Generally speaking the car is in beautiful shape and has been well maintained over the years and I feel like I found a prize (other than this issue for which I am posting.
I had it with a mechanic today who pretty much works on Porsche-- he said he could not tell me what the problem was of yet, but suspected electrical and wants me to bring it back next week. Any other ideas? Anyone have a similar experience?
Your help is appreciated!
Old 08-22-2008, 08:57 PM
Formerly reformed
Does it have an aftermarket ignition?
1968 911P (Paperweight)
Old 08-22-2008, 09:00 PM
I don't believe the ignition is original, but I can verify with the mechanic as he's performed all the maintenance on the car over the last 12 years.
Old 08-22-2008, 09:23 PM
Correction: I do believe the ignition is original.
Old 08-22-2008, 09:24 PM
madmmac's Avatar
More info would be helpful..last tune up...last valve adjust...last air and fuel filter change.
Check to make sure you are actually getting full throttle. Have someone floor the car while the engine is off and check at the engine that the throttle is just contacting the stop. If not, shorten the linkage under the car by the transmission until it does.
With the wavering speeds, you may need to move the wiper in your maf. This describes the process for a 944, but it is pretty much the same for a 911.
http://www.clarks-garage.com/shop-manual/elect-22.htm
And Welcome aboard!!!....now post the obligatory picture of your car.
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 08-22-2008, 09:38 PM
I would check the throttle to ensure that its at WOT when the pedal is floored.
Provided that the plugs, wires, cap & rotor are all in excellent condition and the fuel filter is new, I would have your mechanic check out the cat. They can get plugged up and that certainly fits your symptoms.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-22-2008, 09:49 PM
Formerly reformed
Oops! I made a fox pass. Welcome to "the bored".
Old 08-22-2008, 10:11 PM
Living up to the name
VroomGrrl's Avatar
Welcome!
I am like the court jester of the forum, all stupid questions and accidentally brilliant answers, delivered while dancing around in a pointy hat and shoes!
Let me try my skills out on you.
Could the PO have adjusted the rev limiter down to 4500?
2008 911 (997) C4 Carrara White
The sweet old 1988 911 GP White has gone to a new owner
"Keep your head in the clouds and your right foot mashed to the floorboard!" ~Village Idiot
Old 08-23-2008, 06:22 AM
What is the "Cat"? Catalytic converter?
Old 09-15-2008, 08:45 PM
Thanks for your response. I take some pictures and will get them uploaded soon.
Old 09-15-2008, 08:49 PM
Boomtown Rat's Avatar
Porsche Crest Flattening out at 4,500 rpm
Hi there! Have you replaced the DME yet? Trivial part (under your driver's seat) that can cause the weirdest of phenomena. I had one go bad in my `86 Cabriolet (now sold) a couple of years back and it started the same way that you're describing your problem over 4,500. It just got worse and worse, until the car wouldn't accelerate at all. Switched out the DME (cost something like 50 Euro and took 30 minutes) and all was well again. Good luck!
Old 09-16-2008, 04:01 AM
