WUNDERWAFFE
JINKATIN's Avatar
Loss of Power and Black soot
Hello. everyone
I need your help!
I have a 86 carrera 3.2, and I had the valves adjusted 3 weeks ago and it seems that I have lost some power especially when I am shifting to third and fourth gear. Their is black soot on left and right side of the rear bumper.
Thanks,
jinkatin
Old 09-16-2008, 10:05 AM
Check the cylinder head temperature sender, the old style one can fail and engine will run too rich.
Pull off the white wire connector (left side of engine, above the two black reference sensor connectors) and have a look at the wiring plug on the engine, if it only has one terminal, it's the old one and should be updated.
Pelican sells the update one.
You should also check the date of the fuel pump/DME relay (under the driver's seat) if original replace with new.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 09-16-2008, 11:11 AM
WUNDERWAFFE
JINKATIN's Avatar
Thank you, I will do that this weekend.
Thanks again,
jinkatin
Old 09-16-2008, 12:17 PM
