new SC spring plates?
Who sells new factory SC spring plates?
i'm trying to compare them to the sway-aways. thanks |
Try these on for size:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_SUSprf_pg34.htm#item33 |
Chuck's products are far superior to the Throw-Aways --- I mean Sway-Aways.
what type of driving do you do? He also has some that will help correct susp. alignment changes. And Wevo makes some with needle bearings. Read his web site, do some searches and decide. |
thanks for the links guys.
I know about the ER and the wevo products. I'm still trying to compare them to the factory SC plates. how much are the factory SC plates? |
New factory spring plates are $634.95/each. The only instance where I will buy factory ones are for a 100% restoration. ER's are far better. |
| All times are GMT -8. The time now is 11:49 AM. |
