-   -   Row??? (http://forums.pelicanparts.com/porsche-911-technical-forum/430857-row.html)
wurls 09-17-2008 06:36 AM
Row???
I need to ask you knowlegable pro's out there something about my car.
I have a 1988 Carrera 3.2 that is a Japanese model. I have never known if my car is truly considered a RoW car simply because it is not a North American model, or because it has the higher HP engine (which I'm still not sure if mine does).
My belief from research is that the car has the North American engine (217HP), but has some aspects that are of Euro spec. (i.e. the rear porsche reflector, side marker signal lights, etc). I'm confused! I have several books on the older Carrera's and one says it should have the higher HP engine, and the other doesn't. Nor did my car come with an owner's manual.
If someone can confirm whether my car is considered a RoW, and what engine this car would have in it.
Thanks a heap!
911st 09-17-2008 06:45 AM
What is the motor type number on the motor by the side of the cooling fan?
Should be something like 930/21 if it is a USA spec motor.
Bill Verburg 09-17-2008 06:53 AM
The engine used on Japanese 3.2 Carreras varied by year.
For 1988 all Japanese manual trans engines were the cat equipped 930/25 217hp, the same as used on US cars. Don't confuse engine specs w/ chassis specs, they are controlled by different agencies.
silverc4s 09-17-2008 06:59 AM
Right hand drive?? In Canada?? Why??
wurls 09-17-2008 07:14 AM
The car is a left hand drive. I heard that having a left hand drive in Japan (where they drive on the left), is a bit of a novelty. (like Japanese eating pizza!)
tincan 09-17-2008 07:41 AM
Same reason as in Ireland, better selection of well maintained cars with service history at reasonable prices. Takes a bit of getting used to though, especially for front seat passengers. I'm becoming accustomed to driving with my left mirror in the hedges while my OH screams about crossing into oncoming traffic
Noel
'88 3.2 Carrera Venetian Blue
gtc 09-17-2008 10:58 AM
Wurls, does your car have a wacky back seat?
wurls 09-17-2008 12:54 PM
Nope. Same back seat as other 911 3.2's have. Smooth supple leather.
Zeke 09-17-2008 02:55 PM
I want some Japanese pizza.
Sorry and I can't help on the RoW issue either.
But, my main question is what's an OH?
"while my OH screams"
tonythetarga 09-17-2008 03:05 PM
my guess is Other Half.
javadog 09-17-2008 03:16 PM
If it is a left hand-drive car, it may not be an actual Japanese-spec car. If you'll post the VIN number and engine type number and serial number, we can probably figure out what it is.
JR
wurls 09-17-2008 07:19 PM
JR
The VIN # is WP0ZZZ91ZJS109882
The engine number is 64I05453
Now, as far as the serial # goes, is it not the same as the VIN#?
Hope these numbers help. Looking forward to hearing the feedback as to exactly what kind of car I have.
Thanks!
Daviboy 09-17-2008 09:48 PM
Wurls,
Your car is a ROW having the ZZZ in the VIN number. Check here for VIN numbers 1988 http://www.911specs.net/VIN87s911.htm
Your car is 4th down in the 1988 list states a 217hp motor and is one of 430 built.
BTW your motor is a 930/25 type.
tincan 09-18-2008 02:59 AM
Tony G.
86 911 3.2
Right on the money Tony, I knew I was going to have problems understanding some of the technical terms used but seems like the traffic is both ways, separated by the same language
Noel
javadog 09-18-2008 03:18 AM
Wurls,
That chassis number shows to be for a Japan spec coupe. You might double check the engine number and see if it is actually 64J05453. The I in the third position isn't correct.
The engine is the same as the US spec engine for that year.
JR
wurls 09-18-2008 09:01 AM
Daviboy,
Thank you very much for your assistance in helping me to finally find out what kind of 911 I really have! I looked everywhere online for a website like the one you attached the link for, but couldn't find one.
Last question...do you think that the 217hp engine will revert back to somewhere close to the 231hp range if the catalytic converter is removed and a performance exhaust (in my case, a Fabspeed) is used? Again, any help is greatly appreciated.
Thanks!
wurls 09-18-2008 09:03 AM
Originally Posted by javadog (Post 4187711)
Wurls,
JR
I'll double check the third character on the engine number. It might just be a "J" and not an "I".
I'll let you know.
911st 09-18-2008 03:37 PM
Originally Posted by wurls (Post 4188192)
Daviboy,
Thanks!
Comes close.
I added a cat bypass pipe and 911Chips.com chip and pulled 215-217 HP to the rear wheels on a dyno that is supposed to run low (ya right). That is 250+FWHP.
If you do put a sport muffler on it a friend w the same motor, chip, dyno, and day pulled about 7RWHP than I. The only real difference was a Bursh sport muffler.
With or w/o a chip 911's respond well to exhaust changes. The factory seems to have set to run rich under WOT. Freeing up the exhaust makes it easer to breath and puts us usually at a more favorable air fuel ratio.
If you want to confirm you motor there is a motor type number on the horizontal case surface behind the vertical motor serial number. It can be hard to see but it is there. It will be that number like 911/25. Wiping the surface and using a small magnifying glass helps.
Daviboy 09-18-2008 11:33 PM
Daviboy,
Thanks!
wurls,
Those questions I will leave to the other experts I cannot comment on this apart from to say any exhaust mod will free up more horses..
Davy
911st 09-19-2008 06:12 AM
Do you have the correct SW chip?
If you told Steve you had a euro car you may have received a chip to work w a higher compression motor and you would be leaving HP on the table.
wurls 09-19-2008 07:18 AM
The dealership I bought the car from ordered the chip and installed it. The would have ordered a chip for a Porsche with North American engine specs, since I have been educated a little more on my Carrera, and now know that even though it is a RoW Carrera, it has the 217hp American spec engine in it.
I WISH it had the Euro engine in it though!
Can't have everything.
nouga88 10-02-2012 05:06 AM
Hi all, i have a japanese "88 carrera and i wonder why it wheight 10 kg. more then the US model?
Drisump 10-02-2012 06:06 AM
There are quite a few Japanese spec cars in this area (lower mainland of BC) and I have only ever seen LHD examples. In Canada we are allowed to import Japanese sourced cars if they are over 15 years old, that is as opposed to the US where they need to be 25 or more. I'm not sure why in a RHD drive country they seemed to have only brought in LHD examples. As was said before, the Japanese spec cars have a lower compression motor with more pollution control equipment....seems to be exactly the same as North American spec cars. Some (if not all) of the other "Euro" cosmetics seem to be there however (lights, rear bumpers, etc.). My 85 Euro ROW also has a transmission cooler in it's 915 tranny. The G-50 didn't have one, or need one for that matter, but I believe the 915 trannnys from Japan did not come with the cooler. Good luck and have a great time with her.
Canada Kev 10-02-2012 06:55 AM
I have noticed that almost all cars imported into Japan have the steering wheel on the side of the native manufacturing country - LHD for German and US cars, RHD for UK or Australian.
I have also noticed that they often have some other unique things like the funky back seat with the upholstery continuing from the base up and over the transmission hump. The lighting seems to be in line with Euro specs (RHD) while the engine the engines appear to fall in line with NA models.
