934 wheel and suspension specs?
I need help spec'ing wheels for a 930 with 934 add-on flares.
Does anyone know what width and offset wheels the original 934s used? Maybe tire sizes too?
I am assuming that the suspension pick-up points, arms, etc where the same as a 930's and not altered like on the 935s. Correct
Old 09-23-2008, 09:40 PM
Where are all the 934 gurus?
Old 09-24-2008, 05:29 PM
msucro's Avatar
Send a message via AIM to msucro Send a message via Yahoo to msucro
Hi,
I may be oversimplifying things but if you know the desired wheel width, spacer width, and what fits on a 930, you could just determine it from there...at least you could determine a minimum backspacing and build it out from there?
Marcus
Old 09-26-2008, 11:48 AM
