Question Sunshine BUT NO SUNROOF
Hey all
i have a problem with my sunroof. well today in Perth it was a great day sun was out & first thing i did when reversing out i tried opening my sunroof which i do nearly everytime i am in the car. BUT today it didnt want to open
the s/roof motor is working (sounds like it anyway) fine but from reading on here it could be a cable? my question is before i start to try and atemp this removel of the s/roof what should i look for?
cheers
MELO 911
911 3.2 CARRERA '88
JEEP CHEROKEE KJ '04
Old 09-20-2008, 01:48 AM
Designer King
Paulporsche's Avatar
2 things to check:
Aside from the cables, check the clutch which is that small cocktail sausage like thing between the motor and the transmission.
Also, when mine stopped working, I opened up the transmission and changed the small gear inside which had worn down. That fixed it until the motor went about 15 yr later.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-20-2008, 08:28 AM
dshepp806's Avatar
I've a broken clip that's blocking my opening,...on the list of to-do's..
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-20-2008, 03:07 PM
thanks guys ill look at checking it out next weekend.
got both the bentleys & wayne's 101 books out & check it out.
MELO 911
911 3.2 CARRERA '88
Old 09-20-2008, 08:22 PM
