80 Euro distributor question
My distributor does not have vacuum advance and No provisions for the diaphragm.
It has a Bosh part # 0237 303003.
It also has 050 that is circled and another set of digits PGFD6.
Anyone know what year/application this is for? I am pretty sure all of these cars came with vacuum advance.
Silver 1980SC Euro coupe
Old 09-24-2008, 09:18 AM
Anyone?
I can not find away to look up a Bosch part number.
Old 09-25-2008, 05:04 AM
Check out distributor 18, it has a pn#930.602.021.00
http://www.madebyporsche.nl/index1.html
This post refers to a 0237301007 part number, translation is a little rough.
http://translate.google.com/translate?hl=en&sl=fr&u=http://www.type911.org/forum/forumread.php%3Fi%3D172745&sa=X&oi=translate&resnum=5&ct=result&prev=/search%3Fq%3D0237303003%26hl%3Den%26safe%3Dactive% 26sa%3DG
I can check mine when I get home. Did you check with Milt?
John Adams
1980 ROW 911SC
Old 09-25-2008, 06:38 AM
Thanks John! Who's better than you?
From that site it looks like Bosch# 0237 303003 equals 93060202100 in Porsche language. Now I should be able to figure out what car it belongs to.
Hopefully we can crack the code.
I just checked Pelican and it is no longer available. but I can buy 930602021DX for 1,145.00!!
Old 09-25-2008, 07:44 AM
Less brakes, more gas!
euro911sc's Avatar
I'll check mine when I get home...
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 09-25-2008, 07:55 AM
Mine is a Bosch 0237301007, with vacuum advance. Mine also has 050 that is circled and another set of digits PGFUD6. The "U" must stand for "um-vacuum"?
John Adams
1980 ROW 911SC
Old 09-25-2008, 01:23 PM
These links provide the info for your distributors
PG = Gehause = pole housing diameter between 71mm & 83mm
F = Fliehkraftversteller (mechanical advance)
U = Unterdruckversteller (vacuum advance)
D = Drehzahlbegrenzer (speed limiter)
6 = #cylinders
0 237 303 003
0 237 301 007
http://www.automotive-tradition.de/download/kennlisten/elektrik/zuendverteiler/erlaeuterungen.pdf
John
Old 09-25-2008, 02:10 PM
jcge,
Thanks for the links, good info. Can you determine what Ron's distributor application is? I believe mine is the original ROW distributor that came with the car.
John Adams
1980 ROW 911SC
Old 09-25-2008, 02:54 PM
Originally Posted by Jadams1 View Post
jcge,
Acording to the Bosch literature
0 237 303 003 = PGFD6 (Porsche OE# 930.602.021.00)
Porsche 911 3L; Europa beginning March 1978
0 237 301 007 = PGFUD6 (Porsche OE# 930.602.021.04)
Porsche 911 3L; Europa beginning February 1979
Note that these are Bosch's records.....Porsche may have transitioned at different dates.
John
Old 09-25-2008, 03:16 PM
Thanks for all the info!!
That solves that mystery. Now I'll have to check and see if I am getting full advance.
Old 09-29-2008, 04:06 AM
Because you couldn't keep up with me on RT102, I would say you are not?
John Adams
1980 ROW 911SC
Old 09-29-2008, 05:42 AM
Do not confuse " not keeping up" with YOU WERE IN MY WAY
Old 09-29-2008, 06:04 AM
