How to cut braided oil lines
I know this is a dumb question, but installing used aux oil cooler lines , They are braided rubber with stainless inside. I need to trim a piece off one but trashed it using my method .........Obviously there is a method or tool to do this cleanly. Any help would be appreciated.
Terry
TOT |
I wrap the area to be cut in masking tape and use a Dremel with a cutting disk.
I say we take off, and nuke the site from orbit. It's the only way to be sure. 2009 Cayman |
Yup, wrap with Duct tape and use a Dremel or air powered cut off wheel.
You can use a hacksaw but these methods work much better.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Out in the field Ive never had any problems wrapping it 3 or 4 times around with electrical tape, put in a vice and saw the excess out of the vice with a fine tooth hacksaw
theres nothing like the rear end squatdown of a turbo |
RETIRED
I prefer electrical FRICTION tape, the stuff that looks like cloth. Duct and vinyl tape tends to heat up and leave a residue. Three four turns....some ferrels can be sliped on, then shoved down the braided line. Do the cut, pull the tape, slide the ferrel to the end, assemble.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
line fittings
Thanks guys ......Learned a couple tricks .......The fine tooth hacksaw would have saved me the mess I created. All helped so I am well covered ...Thanks again.
Terry
TOT |
Navin Johnson
We use a cable cutter that looks similar to this..
![]() snip and your done... no loose wires etc.. I got mine from grainger me thinks.. http://www.grainger.com/Grainger/items/1YNB4
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
