78' 3.0 engine wiring issue
I am currently installing a 3.0 carrera engine from 78' in my 71' 911. The engine is in place and i am wondering if anyone has a diagram for the wiring harness that ends with the 14pin plug. ( for all connectors on the harness ). I have searched the web without luck.
Also, i assume i do not have a ignition control unit that works with this engine. Is an original one easier to install or should i go for one of theese If anyone have links to threads by people doing a similar engine swap i would be glad to get them :) Best regards Roger |
Here is a picture of the wires, i would believe maybe nr 1 goes to the fuel pump? and number 3 to the ignition control unit. But do someone know for sure, that will help me a lot :)
http://forums.pelicanparts.com/uploa...1222282952.jpg |
I'll take a shot at your plugs. No. 3 is definitely your CID module connector. No. 1 looks like the heater blower connector, but it shouldn't be harnessed there with those other connectors. No. 2 I've never encountered, maybe a rear windshield wiper connector?
Brian |
I just wen through this same thing the number two is your voltage regulator plug.
number three is the ignition box and number one plug on my 75 has a tach signal running through it i reired this to work with my 78 sc harness to the 75 car do a 14 pin connector search and you will find my thread but the 14 pin is as fallows for 78 CS pin # 1 starter relay *yellow* 2 rear fuse panel *green* 3 oil temp sensor green/black 4 oil pressure sender green/red 5 backup light switch yellow/green 6 backup light switch grey/brown 7 rear fuse panel blue/yellow 8 shift lever harness brown/white 9 oil pressure switch green/white 10 cis warmup red/white 11 D+ *blue* 12 tach black/violet 13 heater blower relay yellow/black 14 B+ *red* I got this info on this forum from another pelican member hope this helps |
Roger, many seem to prefer the stock Bosch CDI ignition units like this over the aftermarket solutions out there. It has the 6 pin male connector for the plug you show.
http://members.cox.net/3.6/images/6pin.jpg Do a search here - this has been discussed many times over. Cheers, Ingo |
| All times are GMT -8. The time now is 06:17 PM. |
