-   -   h4 conversion help (http://forums.pelicanparts.com/porsche-911-technical-forum/431741-h4-conversion-help.html)
vtrich 09-22-2008 12:17 PM
h4 conversion help
I'm converting my H5s to H4s and am pretty much set to go. Had a local shop paint the trim ring (gran prix white) and am planning on cutting out the old H5 plug and splicing in the plug that works with the H4 bulb. I bought 2 pigtail plugs from the local NAPA store, but the wiring feels like it might be too small a gauge. I did buy 2 plugs from Pelican, without the spade fittings,..but I can't find anyplace that sells the spade fittings,..at least fittings that actually fit into the plug. UGH! Any ideas,...or do you think the wiring on the NAPA plug should be suitable?
THANKS!!!
Rich
spuggy 09-22-2008 09:46 PM
THANKS!!!
Rich
Where you should have gone in the first place for high heat headlamp sockets :D
http://www.danielsternlighting.com/products/products.html
