torsion bar stiffness % ??
When upgrading coil spring suspensions, it's common to refer to a new spring as xx% stiffer than the factory spring. Does anyone know the percentages for the torsion bars offered?
In the front, 22mm is what % stiffer than 19mm?
In the rear, 27mm is what % stiffer than 23mm?
thanks,
geoff
Old 09-22-2008, 11:35 AM
She/Her
BeauBlues's Avatar
I'm not 100% sure, but I believe that for every mm, you increase stiffness by 4x.
Gwyneth *she/her
1995 993 Guards Red
1984 911 Targa with a G50 (RIP)
Old 09-22-2008, 11:39 AM
do you mean 4 times or 4%?
4 times is a little extreme, right?
so going from 19mm to 22m would mean 1200% stiffer.
Old 09-22-2008, 12:50 PM
David's Avatar
Like this:
Old 09-22-2008, 01:00 PM
Zeke's Avatar
Here's an old thread from Will Ferch:
"I'm providing you with this to be an "informed consumer"...
Your 86 was likely delivered with a 18.8 front bar and a 25 rear bar. The equivalent spring rates are 110 lb/in front... 140 lb/in rear. Stiffer rear ( only) will promote oversteer....stiffer front ( only) will promote understeer. Here's a breakdown of front and rear TB sizes and their spring rates, after my exhaustive investigation on sizes, bar lengths, pivot arm lengths, etc:
Front:
18.8= 110 lb/in
21= 173
22=210
23=250
Rear:
24=120 lb/in
25=140
26=165
27=191
28=221
29=254
30=294
31=332
33=427
Notice some interesting trends.... many people say to upgrade to 21/27...or 22/28. The 21/27 combo equates to 173/191...and the 22/28 combo equates to 210/221. In both cases...fairly equal. This maintains the front/rear balance Porsche designed into these cars, but some say (me included) that we can go proportionately stiffer in the rear to dial-out some unwanted low speed understeer. So...maybe 21/28 ( 173/221)....or 22/29 ( 210/254). But look what you're contemplating:
21/31 ( or 173/332). IMHO...this is too much rear bar...and the overall stiffness for the rear is over 2.3 x as stiff as stock.... !"
What this doesn't cover is the wheel size and offset. That factor will change the rates if not stock.
Old 09-22-2008, 01:02 PM
ToddM's Avatar
Send a message via AIM to ToddM Send a message via Yahoo to ToddM
thanks,
geoff
The formula for calculating spring rate is: k=d^4G where k=spring rate, d=diameter, G=modulus of elasticity (constant for steel)so ignoring the constant:
% increase in stiffness = ( (d2^4)- (d1^4) ) / (d1^4) * 100
where d2 is new diameter and d1 is original diameter
To answer your question:
19 to 22m front active rate stiffness increase as a %: 49.23228029
23 to 27mm rear active rate stiffness increase as a %: 89.90819787
-Todd
'82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs.
Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete
Old 09-22-2008, 01:36 PM
thanks guy, good information.
Old 09-22-2008, 02:30 PM
dshepp806's Avatar
you better believe it,....good stuff!!
Thanks!
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-22-2008, 02:58 PM
