-   -   Window Squeegee Length (http://forums.pelicanparts.com/porsche-911-technical-forum/431752-window-squeegee-length.html)
Oregon Cab 09-22-2008 01:28 PM
The rubber blade that squeegees the window when it rolls down into the door; is it supposed to go perfectly in length from wing window all the way to the rear edge of the glass? Mine looks to be about a half inch or so short and I am concerned that it is going to allow excess water into the door.
Rot 911 09-22-2008 01:35 PM
They shrink over the years. Time to get a new one. While you are at it make sure the drain holes in the bottom of the door are open.
Oregon Cab 09-22-2008 01:49 PM
Thanks! This all makes more sense now. Yes the drain hole tip probably just saved my life.
dshepp806 09-22-2008 03:01 PM
My new ones fit perfectly,..I couldn't imagine how much the originals had "shrunk"...
Best,
Doyle
Oregon Cab 09-22-2008 03:42 PM
At least a fingertip or more. The right side was the same as well so I was perplexed. I could slide the seal with a nudge fore or aft and it appeared to be in good repair. This forum is the best.
