Burint's Avatar
Can paint remover be used for cleaning the case?
Hello,
I have read from the old post that paint remover will not harm anodize but can I use it to clean the inside of the engine case when do the rebuild?
The Unbreakable RS/RSR door pull http://thaiporsche.shutterfly.com/776
86, 930.
70, 3.2.
67, 911.
Old 09-23-2008, 09:25 PM
MEMBER # 930
waynesco1's Avatar
NO!!!!!! < Cleaning solvent- compresed air >
Old 09-23-2008, 09:46 PM
oneblueyedog's Avatar
I did on the perimeter sealing edge on the outside of the case to get rid of the old sealing compound. It worked well. Use a soft plastic scraper to scrape the goo to the outside of the case when you clean it.
I would not use it in the case though. I left the brown color on the inside alone.
78SC coupe, Silver Metallic
Old 09-24-2008, 05:05 AM
