-   -   headlight problem (http://forums.pelicanparts.com/porsche-911-technical-forum/431983-headlight-problem.html)
jj4u3 09-23-2008 05:38 PM
headlight problem
I can be driving down the road at night and my headlights will sometimes burn brighter for a minute or two and then burn dim for a while. Doesn't matter if I rev up the engine or not? I recently blew a fan belt and replaced it. Could it be that I don't have it tight enough or do you think maybe a short? 72 911T with 3.2
dshepp806 09-23-2008 05:42 PM
not familiar w/ your year,..but is the regulator OK?
best,
Doyle
Cooper911SC 09-23-2008 05:52 PM
Likely voltage regulator going. Check the alternator output at the battery while car is running. It should be around 13.8V or so. Not much higher.
Mine stuck and overcharged the system...ended up burning out my headlight bulbs!
Cooper
jj4u3 09-23-2008 07:07 PM
thanks it is going to the shop for another problem Thursday. I will have them check the voltage regulator and the altenator output. you guys are great, thanks
911s55 09-23-2008 07:14 PM
Check ALL of your ground straps.
