cdi rebuild service systems sc
Can anyone give me a referral on Systems SC Manhattan beach CA, I think I need my CDI fixed or replaced, but before i send then the CDI i would like to hear from someone.
The business is owned by a guy named Loren. He used to post here under the name "LorenFB." He was very combative and at times difficult, but one thing that came through loud and clear was that he knew what he was talking about when it came to Porsche electronics. Fortunately, I have not needed his services, but I would send my box to him if I had a problem.
HTH. Scott
1984 Targa |
81 white
What are the symptoms that lead you to this conclusion that CDI is on the way out? Just curious. |
ischmitz does it on this board...
Tim 1986 930 Gone:71,2,4 914's, 70T, 71T(RS),77S |
I sent you a PM 81white911
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
why i think the cdi is bad
I tried taking a used spark plug and grounding it to check spark. Got good spark but intermitant. Then i tried the same with the cable from the coil. and got the same results. I havent checked the coil. waiting for someone to tell me how. Also, the engine quit twice a month ago when it was still running. It had been idling with the hood up for a long time (high temp in the engine bay) and it just died then i couldnt start it until the next day. I went through an exhaustive fuel check, clean, repair. and i cant start it now. so maybe the CDI started to fail at high temp and now its just messed up. I did look at the green wire, its spliced but done properly as far as i can tell. Right now its worth the money to get a good CDI, if that doesnt work ill let you know.
81 white
thanks for your theory. Curious because on my 81, it occasionally hiccups at idle (like a few times a year or less) but stays running. Sounds like the car is being turned off momentarily which has me thinking CDI is a little old and quirky. Wires, cap, rotor all fine. Just wanted to validate my thinking with yours. thanks. |
The CDI box can intermittently fail (latch up under temperatue) - but typically these failures require you to power-cycles them (turn the ignition off and back on)
Your phenomenon could be a trigger wire failing or shorting out. These coax wires get brittle with time and can lead to an unstable trigger signal to the CDI box. Ingo
Ingo
Where are these trigger wires you speak of? Coax wires? Thanks. |
It is the green wire that is connected to the distributor.
ischmitz trigger wire
Why do people splice these trigger wires? I havent found a replacement wire. After it leaves the distributor where does it go?
The green wire eventually ends up at the CDI box as two of the 6 connections. Lots of info (lots!) search on green coax or green wire. For example http://66.236.61.177/showthread.php?t=358877&page=2
The replacement Pelican sells is a pigtail, on many SC's the original is one piece from the CDI to the distributor, so to fix you must splice in a connector. I just had to do this, the wire was pretty stiff, when I pulled it out of the distributor the connector just crumbled in my hand. Jay
2002 Boxster Speed Yellow |
I was told you can use the "Green wire" from a 928, it's longer (and cheaper for some reason). Not sure if it's true or not..
Gary R. |
RETIRED
Ingo or our host.....Loren does good work but he makes Marquis de Sade look like a choir boy.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I was able to "troubleshoot" my CDI by borrowing one from my local independent shop. The tech took the one off his car...and my car ran fine. Instead of rebuilding my CDI I went with the MSD 6AL electronic ignition and MSD blaster coil (bought both cheap on ebay) and have not had a problem since.
sudo apt-get purge 930
I have the 928 wire in my car. It's long enough to go straight to the CDI and I crimped new ends on and inserted them into the CDI plug. When I bought it the price was around $120.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
green wire trigger
thanks for the advise, it looks like my green wire has been replaced and spiced before i bought it, not alot of hours on the car since i have purchased. The CDI is on its way to get checked. Ill keep you all posted.
