Wheels
what is the biggest n widest set of wheels you can install without tires rubbing fenders on a stock 1976 911 (narrow body) ?
911 TARGA 1976 - 3.2L, G50 SHORT BELL HOUSING. Toyota Hilux 4x4 2000 VW tuareg 2009 3.6 HONDA SH350 |
probably 7" wide (15x7 fuch wheels)
what about 16" or 17"?
16" will work, (my cousin has 16" fuch on his stock 72 911T)
17" may be getting too big... it may not look good. |
You could probably fit 7x16s with 205/55-16s. IMHO, 7x15 with 225/50s all around is about the best you can hope for.
Nothing is guaranteed on these cars, though. I would suggest test-fitting a set of what you want before buying something.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
16x7 "951" offset wheels work well. A 205-55-16 works well and you can sometimes use a 225-50-16 on the rear as well.
You can sometimes run the "951" offset 7's and 8's on the front and rear. I have this setup with 205 on the front and 225 on the rear. You would likely need to roll the fender lips and even then may run into clearance problems. Each car is different so this might not work for you even though it works for me. Good Luck! ![]()
^^ That is badass.
Yah I dont think I have seen your car before...love it. Not usually such a huge fan of the narrow hippers.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
thanks for the answers what is "offset" in this mean please?
I had 951 8's on my '74 with 225/50s
'63 356 S90 Ivory/Red '70T coupe Burgundy/Tan '71 914 Canary Yellow '72 Datsun 240Z Orange/Black '65 Chevy C10 shortbed fleetside Butternut Yellow |
