A/c low pressure fiting
Dear All
Witch fiting on the compresser is the low side 911 1989 C4? Thanks Andrew |
I believe it is 7/8" Fitting on the Low Side per Bentley Guide.
To be certain why not just measure it? |
Both fitting are 7/16 and I tring to add a fitting to mesure and the adapter has locking Adhesive to prevent removing?
Andrew |
Loctite? Really? Hmmm.
If I may suggest break it loose, cap it off then go to a hose manufacturer and verify the size and availibilty. This what I did when I replaced my 16 foot long driver side hose from rear condensor to front condensor. According to the Hose manufacturer these are standard AC fittings. |
| All times are GMT -8. The time now is 11:42 AM. |
