A/c low pressure fiting
Dear All
Witch fiting on the compresser is the low side 911 1989 C4? Thanks Andrew |
Member 911 Anonymous
I believe it is 7/8" Fitting on the Low Side per Bentley Guide.
To be certain why not just measure it?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 09-25-2008 at 02:39 PM.. |
Both fitting are 7/16 and I tring to add a fitting to mesure and the adapter has locking Adhesive to prevent removing?
Andrew |
Loctite? Really? Hmmm.
If I may suggest break it loose, cap it off then go to a hose manufacturer and verify the size and availibilty. This what I did when I replaced my 16 foot long driver side hose from rear condensor to front condensor. According to the Hose manufacturer these are standard AC fittings.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
