-   -   Heater switch light bulb replacement (http://forums.pelicanparts.com/porsche-911-technical-forum/432574-heater-switch-light-bulb-replacement.html)
Cattler 09-26-2008 03:46 PM
Please help!
I have the manual three-way fan speed switch in my heating unit. The light bulb's burned out and I can't tell in the dark whether its in "1", "2", or "3". How do I change that bulb? How do I reach it? The Bentley manual isn't clear on this.
DRACO A5OG 09-26-2008 06:50 PM
Hey Cattler!
Welcome Aboard.
You need to remove the plastic housing held by 4 allen bolts. Use a small straight edge to lift the lever off the assembly then unscrew the assebly from the housing.
Once you remove the assembly, you wil notice only one buld, I believe it is a blade type bulb #72? Memory unclear, sorry.
The Dial is a one piece clear plastic with red paint and white numbers and defrost logo.
Break a leg.
