curlesw's Avatar
Failed CA smog, couple of questions
Just failed smog on my 83 SC, couple of questions. First details:
25 mph, CO Max = 0.79, measured = 1.24
Ignition timing failed (odd).
1. So is the failure of CO related to timing and should I just ensure the timing is correct and go back for the test (note, CO measured at 15 mph was close, measured 0.94 vs a max of 0.99).
2. Or, just take it to a shop and have them check the air/fuel mixture.
Note, I have had the engine in/out 3 times chasing oil leaks (finally fixed them), which included removal of the entire CIS.
v/r
Wayne C.
Old 11-22-2008, 01:31 PM
Fuchs w h o r e
How far off is the timing?
Old 11-22-2008, 01:41 PM
curlesw's Avatar
It does not say.
There is a note that states "This vehicle failed the ignition timing check due to the engine rpm being out of tolerance.
v/r
Wayne C.
Old 11-22-2008, 01:48 PM
Fuchs w h o r e
Your idle speed is probably too high. Get your timing light out. It would be foolish to change anything else until you correct this known error.
Old 11-22-2008, 02:07 PM
efhughes3's Avatar
Hey Wayne, what part of Escondido do you live in? I'm over in the NE corner just before popping over to Valley Center.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 11-22-2008, 02:10 PM
curlesw's Avatar
I have noticed the idle is high...would the timing be off contribute to the high CO emission? I'd hate to fix the timing and then fail the test again (another $70)...not sure if the air/fuel mixture needs a check.
I am over in San Pasqual in the community with Eagle Crest golf course. I sit on the 12th hole about half way down.
v/r
Wayne C.
Old 11-22-2008, 05:09 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
High idle could be caused by advanced timing. Retard the idle to spec, then set the idle rpm. That will probably take care of it but if not you can easily lean out the idle to pass, then advance the timing and richen it up afterward.
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 11-22-2008, 09:31 PM
curlesw's Avatar
Thanks, will give it a try.
v/r
Wayne C.
Old 11-23-2008, 02:20 PM
efhughes3's Avatar
v/r
Wayne C.
Not far at all, maybe I'll see you about sometime.
Ed Hughes
2015 981 Cayman GTS
Old 11-23-2008, 02:22 PM
curlesw's Avatar
Funny, we both have Ruby 911s.
v/r
Wayne C.
Old 11-23-2008, 03:55 PM
Nine9six's Avatar
v/r
Wayne C.
Hmmm,
What about pass or don't pay smog stations?
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 11-23-2008, 05:17 PM
Detached Member
Hugh R's Avatar
This link WILL solve your problem!
Want to get out of SMOG testing your car in CA, use this DMV form!
Hugh
Old 12-01-2008, 01:56 PM
